REPLACING FUEL FILTER
*Remove protective cover.
*Disconnect fuel lines.
*Loosen mounting screws (arrows) and remove filter.
*Unscrew fitting from old filter and attach to new filter with new seal ring.
*Install new fuel filter in flow direction with plastic sleeve.
*Sleeve should project on both sides of the holder since contact corrosion may occur if there is direct contact with the holder.
*Replace plastic sleeve, if necessary.
*Connect steel line to filter.
*Retighten mounting screws.
*Check for leaks.
Jan 10, 2010 at 3:37 AM
