The transmission fluid on this vehicle is filled via the dipstick tube at the right rear (passanger side) of the motor. It will ususally have a black or red cap on the end of the tube. There will be a small plastic lock you will break the end off and then push the remaining piece through. Remove the cap and fill with a funnel. Note that most MB models do not have a transmission dipstick. You can purchase one from most dealers. Also make sure to check fluid level with the trans at full operating temperature with the motor running.
Jan 19, 2009 at 4:44 PM
