1983 Mercedes Benz 300te over heating
1983 MERCEDES BENZ 300TE
250,000 MILES • 4 CYL • 2WD • AUTOMATIC
GIVEMORE
I drive a mecerdes 230te it is over heating and after over heating you can not start the engine until the tempreture gaurge is back to low.
Feb 4, 2010 at 6:29 AM
Do you have white smoke coming out of the tailpipe? If not check the water pump if its functioning if so check the radiator if its clogged okay here replace the thermostat and go from there-Overheating problem will cause the engine to seize due to excessive friction
Feb 4, 2010 at 6:43 AM
