1999 Mercedes Benz 300td not running good
1999 MERCEDES BENZ 300TD
TONYN2002
Engine Performance problem
1999 Mercedes Benz 300td 6 cyl Two Wheel Drive Automatic 200k miles
hi i have the 99 e 300td with 6 cylander i had problem with the performance so i had the troble checked and it was booster pressur switch so i replaced them but still not good ,i checked all the vacum system and everything possible to leak vacum but still not running good and i have some problem with shoutoff valve for injector pump i put that new but it leaks fuel from around it please tell me what i can do i am in Armenia and it is very hard to find parts and i worked on cars for 26 years. thank you
Feb 28, 2010 at 9:49 AM
DR LOOT
  • 2,311 POSTS
you will first have to repair the leaky shut off valve, before the vehicle will run correctly
Mar 5, 2010 at 12:28 PM
