1998 Mercedes Benz 300td Non starter
1998 MERCEDES BENZ 300TD
202,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAWNSWR
Engine turns over but won't start.Lift pump faulty non return valve and repaired but unable to get fuel up through pump. Battery has been taken off and changed. Is there a system of re-setting the car through the key fob?
Jan 21, 2010 at 4:24 AM
DR LOOT
  • 2,311 POSTS
Make sure that the filter located by the pump at the bottom is installed correctly, look at the Aero make sure it is pointing in the right direction
Mar 5, 2010 at 12:15 PM
