1984 Mercedes Benz 300td Dieseling
1984 MERCEDES BENZ 300TD
160,000 MILES • 6 CYL • 2WD • AUTOMATIC
JMONGARE
my car is 5 cylinder diesel motor. The car will not turn of after ignition switch turned off. It keeps running even though electricals are off
Sep 8, 2009 at 11:47 AM
DR LOOT
  • 2,311 POSTS
first of all, it sounds like you've got either a bad vacuum pump or you recently had its service, and when they changed the oil filter. They knocked loose or damaged a vacuum line, check all your lines, make sure they are connected, if they are. You have a bad vacuum the kit for the vacuum only cost about $12 and the overhaul is easy.
Nov 26, 2009 at 6:41 PM
