since I saw a number of related questions in the same regard: my car (inline 6, perfect mechanical condition engine) hesitates to accelerate after the first warm up phase. Take off on intersections is difficult. The operation is too lean. Check: when enriching the A/F by pressing the throttle, the power comes back (revs up to 7200 rpm). Driveability is horroble. When cold (first 90 sec.) power is good, enough fuel coming.
We (mechanic and I) found out that O2 sensor plug is hanging off without finding the counterpart connection to the ECU. Where is the cable to be found? (All wiring for grear and ECU go to passenger side into sealed engine compartment. No routing along frame. Can cable have been cut by preowner when installing aftermarket radio?
All other regular stuff (fuel filter etc. changed). One or both fuel pumps are singing (pressure not measured).
Problem worsened over time, after winter storage radically bad.
Read also about over drive: does not work. Shifts too quickly from 2nd into 4th. Downshift is like waiting for tax refund from government. Any suggestions please? Thanks
Apr 22, 2009 at 2:34 PM
