Engine Mechanical problem
1989 Mercedes Benz 300sl 6 cyl Two Wheel Drive 110000 miles
always starts from colds ometimes a bit reluctant,about once in 10 times.When hot refuses to start about once in 5 times,at such times if i keep cranking for about 15 secs it will sometimes start. When running ig goes faultless. I have replaced --fuel pump relay-distributor cap-leads-rotor-plugs-VOPrelay- battery-idle valve. Plus hours checking all wiring.car does not have lambda sensor or a/c
updated 2-2-09
Thanks for the quick reply--I have replaced the coldstart thermistor in the cyl head- fuel pressure is 4bar running,switch tests out OK. I am told there is a one way valve on the fuel system,that this could be draining it down when hot. do you know where it is located.
updated 2-2-09
Jan 31, 2009 at 6:46 PM
