Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Mercedes Benz
300se
Engine Cooling
Cooling Fan
Temperature Sensor
1987 Mercedes Benz 300se ELECTRIC COOLING FAN
1987 MERCEDES BENZ 300SE
123,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVID BRISLAND
MEMBER
FOLLOW
WHERE CAN I FIND THE CENSOR SWITCH FOR THE ELECTRIC FAN
Aug 31, 2010 at 9:59 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
if your merc has electric fan it will be controlled by a relay switch, should be in the engine compartment on the auxiliary relay panel
Aug 31, 2010 at 9:49 PM
DAVID BRISLAND
MEMBER
RElays are all OK it is the temperature switch I require
Sep 1, 2010 at 10:05 AM
BLUELIGHTNIN6
CERTIFIED EXPERT
coolant temperature switch is on the left side of the engine, at the coolant intake housing.
Sep 1, 2010 at 2:31 PM
