1983 Mercedes Benz 300sd Automatic 200000 miles
Hi all, thanks for any help ahead of time.
I was just given this car by an uncle and it has a few problems I would like some advice on.
First, there is a MAJOR oil leak (something like 2 quarts every hour) that actually sends oil to the windshield from the front of the hood. The ENTIRE car gets covered. I looked around the internet and it seems a lot of people were suggesting the front main seal. Anyone know where else I might look? It only leaks when the car is running.
Second, my brakes have been getting worse and worse but I don't seem to be losing any brake fluid. I saw around here that it may be a vacuum leak? Is that the most likely culprit?
Also, my AC doesn't blow cold. I'm going to have the freon topped off. Anyone know if there is a specific type to use? I saw that there were a bunch of people having problems with the A/C. Is there possibly another problem other than freon? Also, the heat doesn't work either.
I think I saw that vacuum seal problems were preventing windows from moving. Neither of the windows on the driver side work. Is that possibly the explanation or do i need new window motors? The front driver side doesnt respond at all and the rear window does sometimes, though very sluggishly.
Thanks again for any advice.
Jul 22, 2010 at 1:11 AM
