my five cyclinder 1982 sd turbo diesel had a rebuilt trans in 1999.the trans started slipping off the line then shifts up fine. had the trans serviced flushed filter and new fluid, problem went away. have been told the trans is shot,bad bands or seals. recently changed only the fluid also added lucus non slip.now no go in drive, car wont move, but will go into reverse? russell at giant diesel said to drain flush and make sure to drain the tork converter and change the filter?before thinking about another trans?have you guys ever seen this type of situation before?could the trans be very pluged up?the fluid was very dirty when i drained it.
Oct 17, 2009 at 4:22 PM
