1974 Mercedes Benz 300sd Transmission problem
1974 MERCEDES BENZ 300SD
DANPRO
1974 Mercedes Benz 300sd 6 cyl Two Wheel Drive Automatic unknow miles
Goes into gear but doesn't move in any gear. dont feel any vacuum on lines when running, car doesnt shut off after key is off. fluid smells like rotten eggs. cant even find drain plug on tranny pan. please help. thanks.
May 5, 2010 at 7:43 AM
DR LOOT
  • 2,311 POSTS
with your vacuum pump not working, transmission will not work either, you will have to remove the transmission pan to change the oil
Jun 16, 2010 at 2:18 AM
