1993 Mercedes Benz 300e hesitates
1993 MERCEDES BENZ 300E
180,000 MILES • 6 CYL • FWD • AUTOMATIC
BLKMAIL33
while driving from 0 to 20 hesitates on excelliration then it kicks in and then does it when it gets to about 45 i hadn't drove it in the last five days been getting a lot of rain in florida
Oct 1, 2010 at 12:10 PM
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Oct 1, 2010 at 8:56 PM
DR LOOT
  • 2,311 POSTS
sounds like a vacuum leak, perform a visual inspection of all hoses make sure they are not cracked or rotted, due to the high temperatures of Miami I believe you will find the issue.
Oct 9, 2010 at 12:50 AM
