Wont Start
1989 MERCEDES BENZ 300E
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
STAN_WEST
I recently purchased a 1989 300E that sat in the garage for over three years. After replacing the battery,I tried to start the car,I hear the starter engage,but no engine response. I dropped the starter and had it checked,works fine.My question is,could there be a switch or sensor that is prohibiting the car from starting. Thanks,Stan West
Oct 1, 2010 at 5:21 PM
DR LOOT
  • 2,311 POSTS
after the vehicle has sat for so many years the first thing to check is if you have fuel pressure or if the fuel pump is working, most people do not run premium fuel as required by Mercedes, therefore the pump maybe seized
this guide can help
Oct 9, 2010 at 12:58 AM
SOUTHER SPEED
  • 6 POSTS
Checked for cold start injector pulse. Not working. Have feul to distribu ter And to injectors Spark is good
Jan 10, 2020 at 11:47 AM (Merged)
Check the injector solenoid resistance and also for power
SOUTHER SPEED
  • 6 POSTS
Cold start injector has been replaced. No power to it
Check wiring and computer
SEDRICK314
Hey my car will not start this is what I have don't so far new battery new distributor rotor new spark wires new spark plugs new alternator new fuel pump relay switch I have spark fuel is going to spark plugs but when I try to start the car it makes a popping sound then when I step on the gas and try to start it it shakes and pops but does not start I am NOT an expert but I do have a owners Bible what do you think the problem is
Are you sure the spark plug wires are on correctly? Have you checked ignition timing? It sounds like it is out of time.
