1989 Mercedes Benz 300e Ac/Heater & wind sheild wipper
1989 MERCEDES BENZ 300E
LOGANMERC
Air Conditioning problem
1989 Mercedes Benz 300e 6 cyl Two Wheel Drive Automatic 168k miles
My 1989 300E Mercedes Benz still runs great except for two thing. About a week ago heat stopped blowing and the only way i could get myself warm is by driving so the wind would naturally push the heat in to the car. What wrong with it? alos my windsheild wipper fluid doesnt work and i was wondering why.
Feb 10, 2009 at 10:06 AM
GFIMOTORCARS
  • 673 POSTS
Your heater not blowing is due more than likely to a failed blower motor. This is mounted under the passanger side dash. As for the windshield washers, your nozzels could be plugged. To unplug these you will need a thin wire to poke in the nozzel holes. Push the wire in about an inch or so. If this does not free them up, you more than likely have a failed washer bottle pump. This is a black pump mounted on the side of the washer bottle. It just pulls right out of the washer bottle so replacement is very simple.
Feb 11, 2009 at 12:20 AM
