I have replaced the radiator, water pump, fan clutch and thermostat and the car still overheats while driving. Does not overheat while at idle.
Sep 22, 2009 at 6:16 PM
DR LOOT
CERTIFIED EXPERT
when you replace the radiator was the front of it very dirty? with debree? diesels will always cool off at an idle. I think the problem here is due to the extensive work on the cooling system. You air in the system, you are going to have to find a steep driveway or hill to put the car on open up the radiator cap, with the heater on, and see if you can get some air out.
