1990 Mercedes Benz 300d Pre Glow Relay switch
1990 MERCEDES BENZ 300D
ROCKINROGER
Computer problem
1990 Mercedes Benz 300d 4 cyl Two Wheel Drive Automatic
When attempting to start my vehicle, the normal pre-glow light indicator on the dash does not come on as it would normally until the glow plugs reach the desired temperature to start the car. Prior to replacing the part, is there anyway to do an electrical test on it to see if the relay itself is working correctly?
Nov 7, 2009 at 2:41 PM
DR LOOT
  • 2,311 POSTS
Relays are very reliable, put your hand on it have someone turned on the key. If you feel it clicking. It is working, you may have a burned-out glow plug, if they are all turned out, the relay will not even activate.
Nov 26, 2009 at 7:30 PM
