1992 Mercedes Benz 300ce starting problem
1992 MERCEDES BENZ 300CE
132,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALPIE65
the car starts fine and drives perfect, but when you turn it off and try to start it again it will not. leave it a couple of hours and the car will start.. then repeat once turned off..
May 17, 2010 at 11:14 AM
Hi alpie65, Welcome to 2carpros and Ty for the donation
Next time it dies out and refuses to start don't wait for nothing -check if its a fuel or spark problem do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 19, 2010 at 10:10 PM
