1984 Mercedes Benz 280sel Sluggish
1984 MERCEDES BENZ 280SEL
316,831 MILES • 6 CYL • 2WD • AUTOMATIC
VJAY
What is the problem, when the car battles to accelerate. There seems to be power on the onset but when it changes into third with gas pedal fully depressed it struggles to pickup more speed. Really sluggish
May 29, 2010 at 5:48 AM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 29, 2010 at 10:20 PM
