1997 Mercedes Benz 280 Engine not firing & burning oil
1997 MERCEDES BENZ 280
MERCEDESENGINES
  • 5 POSTS
Engine Mechanical problem
1997 Mercedes Benz 280 6 cyl Two Wheel Drive Automatic 175k miles
It is a mercedes c280 sport 97' wich has broken down after a frame work done with lots of effort.
Now the engine has several moths sitting on the garage wich had been waiting for a timing chain riveting tool.
Since it was an 800$ tool we figured out a way to get another timing chain and place it on the engine timed to TDC (or so is what we believe) so we could finally put it together.
The problem is that the engine cranks and fires for a couple of seconds and then goes dead.
The original problem was a broken timing chain and consecutive belnt valves. We suspect the car may have some issues with the piston rings since it burns oil badly enough to throw it from the engine top to the air intake (lots of burnt oil gas firing up from the engine cover intake while we try to fire it.
Again, it fires eventually after some tries, but it does not hold steady; the firing and cranking is a bit rough, and the engine has several new gaskets along with valves.
Could it be the piston rings?.
Could it be the engine head?
Could it be bad timing?,
What would you suggest?
Any help would be much appreciated.
Apr 15, 2009 at 12:47 AM
RACEFAN966
  • 5,029 POSTS
It could all or any of what you listed. Now I need some info what all have you done to the engine? You mentioned timing chain and sounded like you may not have gotten it in time? So get back to me so I can better help.
Apr 15, 2009 at 11:04 AM
MERCEDESENGINES
  • 5 POSTS
We have timed the engine correctly; at TDC from what the manuals and some mercedes specialists said using the guides on the camshaft and setting the crankshaft to 0 as the crankshaft itself has the mark "0T".
Since the engine cranked with no problems I would not believe the work has been done incorrectly.
Now, I have no idea if the valve job has been done right because there were no tools to work the way intended.
I have read on the internet how worn engine heads burn oil and create the effect we have seen on the engine at cranking (throwing smoke up from the engine top intake).
I gues since we have got a rebuilt engine head for 45 dollars used the only way is to test again the one actually on the engine, confirm and then replace it.
I hope to be helpful and I will attach a picture.
Apr 16, 2009 at 9:00 AM
RACEFAN966
  • 5,029 POSTS
Ok with the info given I would recomend doing a compression test. Get back to me with what you get and I will see if it is in spec or not. Thanks.
Apr 16, 2009 at 10:32 AM
MERCEDESENGINES
  • 5 POSTS
We do not have any other methods to check the compression but to use the cork test on the spark pluginlet which had been done months ago.
I will not have any specific numbers though we had no experience with it, so what should we expect or what are other good ways to test the compression without any special tools?
Any help would be appreciated.
I will attaach another picture of the time when the problem had been discovered and the pistons were back submerged on cleaning liquid.
Apr 18, 2009 at 10:05 PM
RACEFAN966
  • 5,029 POSTS
You will need to go to you local parts store and find a compression tester. I need to have the numbers as that is the only way I can see what is happening so I can help you. Make sure you take in a spark plug so you can make sure the threads will match. Get back to me with numbers so we can see what is going on here.
Apr 20, 2009 at 11:23 AM
MERCEDESENGINES
  • 5 POSTS
Since the compression tester we got fits the car we are currently working on, we do not know the difference between the compression of a working cylinder and a cranking cylinder.
The car we are trying to fix does not fire up, but the instructions indicate to fire it up for 15 to 10 minutes prior to testing compression.
Then it gives series of prepairing steps before the tester itself could b used.
We did not find some of the parts the instructions indicated and disregarded them.
Now, we did the compression test on the 1st cylinder by just trying to start up th engine.
The engine does seem to fire up for a while, but when the accelerator is not opening the intake manifold the engine dies instantly.
The compression tested 30, 60, 90, and 120 in the same cylinder at different stroking positions.
If you could help us with the usage of this tester on this type of cars we would greatly appreciate it.
Again, it is a C280 1997 Mercedes Benz which has been sitting for a while now.
Hope this helps
Apr 21, 2009 at 7:55 PM
RACEFAN966
  • 5,029 POSTS
Ok here is what I need you do is a compression test as I will discribed ok. I need you to remove all the spark plugs and then hook up your guage to 1st cylinder and crank it 5 revalutions get me the reading and then cyl. number 2 and so on. Then after doing this put 3 squirts of oil in cyl. number 1 do the test again and then cyl. 2 and so on. Then get back to me with the dry test for all cylinder and the wet test (using the oil). I really need to know what all cylinders are doing dry and wet to be of help. Thanks and get back to me with those readings.
Apr 22, 2009 at 10:13 AM
MERCEDESENGINES
  • 5 POSTS
We have recently changed the piston rings since while we were already at it, why not do the whole job ourselves?
So we ended up changing the whole piston head for all 6 cylinders from a C class almost brand new at a yunk yard.
In the end, the rings themselves had almost no miles left as we took them out.
Of course we first tried to only replace the rings so it could be an almost perfect transition, but the rings were stuck in the piston head and these did not expand at all.
Unlike the old ones, the new ones did expand and did move freely around the ring cavities.
That was one job done.
Now we are putting the engine back together, but since we could not fit both the torque convrter with the gearbox inside the car compartment, we had to take the transmission off as well.
Everything went well though the torque converter bled all 4 quarts out and more leaving the transmission which had already bled some liquid as well with virtually no oil, so we went on and bought one quart at our local mercedes dealership and 2 quarts at autozone along with the transmission gasket and filter.
Now we hope the job to be done right since we re-timed th engine at specs and got the pistons at TDC with the engine out.
Of course we let the engine and engine head spin a little after assembling and timing went with great success though it was a little hard doue to the lack of oil in the cylinder walls for a while until it rotated a little.
The timing rails have been bought and replaced and the engine seems to be ready to fire.
Please let us know if there is anything we could have missed.
Now, is it possible for us to completely drain the transmission ourselves or is it impossible due to probabilities of transmission malfunction.
We mean to change the oil since in several forums we have found that some transmission issues are due to the mercedes oil not being changed and we are only restoring the car after doing some framework on the rear end.
Is it fine to mix both mercedes dealership transmission oil and aftemarket transmission oils in this particular device or is it dangerous?.
also, is it possible to get any issues moving the transmission cylynder-like gears that go into the torque converter a little after pulling off the engine?
thank you for your help
PS: normal psi for a cylinder on several mercedes is around 180 and our old pistons gave us around 120.
May 1, 2009 at 6:46 PM
RACEFAN966
  • 5,029 POSTS
Everythings sounds good so far. As for mixing the trans fluid bought from Mercedes and mixing it with what you bought at auto zone there is no problem mixing it as long as they are the same type like dextron 3 for dextron 3. As for draining the transmission fluid you may not be able to get all of it out but as long as you make sure it is full before starting it no worries. As far as spinning the torque converter that won't hurt anything as you ussually need to spin it in order to line up the bolt holes anyway when the engine is in. Well sounds like you are on your way. Thanks.
May 2, 2009 at 8:30 AM
