1982 Mercedes Benz 240d cruise and door locks do not work
1982 MERCEDES BENZ 240D
299,000 MILES • 4 CYL • 2WD • MANUAL
FRIAR DAVE
1. the door locks do not work and the cruise does not work.
2. at one time the engine would not turn off with the key but my dad had someone work on it b/4
giving me the car.
3. it gets 31-34 mpg.
4. I need a procedure for analyzing leaks in vacuum system.
5. I bought a vacuum pump.
Feb 4, 2010 at 4:19 PM
2CARPRO JACK
  • 11,533 POSTS
My software doesnt go back that far for vacuum diagrams, but it does sound like a source problem.You can use carb cleaner to spray at the hoses, when you hit a leak the engine should react.If you can find where the source line is for the doors, you can access the inside of the doors and plug off the feed line, pump the other end with your vacuum pump and see if it holds, if not there is a leak. Check up nea rthe firewall on thedrivers side, if I remember correctly that is where alot of the feed lines are off the vacuum pump on the engine
Feb 8, 2010 at 7:54 AM
