sorry I misunderstood your question, are those aftermarket turn signals on the mirror? or are they factory? thay are probably LEDs, which I doubt they are burned out, sometimes if you check the loom, in between the doorjamb, you may find some damaged wires, the wires probably run through a rubber boot, peeled back the boot and examine the wiring loom, make sure no wires have been damaged, if they are aftermarket and somebody installed them, the wire that goes to the mirror, will be noticeable in the door jam, make sure you have power going to it.
Mar 26, 2009 at 10:32 AM
