blower motor removal
1990 MERCEDES BENZ 190E
REDDUC01
the problem i have got is that i can feel warm air coming through after a while but the blower is not working.
Can you tell me please how to get to the heater to check it and possibly replace it ,do i have to take the whole dash out?
Cheers
Oct 26, 2009 at 12:36 PM
DAVE H
  • 13,384 POSTS
The blower motor on this vehicle is accessed from the engine compartment
Check the guide below for all causes of no air form vents before you replace the motor, could just be the resistor
https://www.2carpros.com/articles/low-or-no-air-flow-from-vents
See the diagrams below for instructions/pictures on how to replace your blower motor
Oct 26, 2009 at 7:32 PM
LABELLACOQUI
  • 5 POSTS
i need to know where I can get a blower motor and how to install it.
Oct 30, 2018 at 5:55 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
to find a replacement check sites such as ebay.com, craigslist.com and car-parts.com. also call your local salvage yards. as for replacement steps, see attachments below..
LABELLACOQUI
  • 5 POSTS
thank you so much. I also had another question do you know where i can get another battery for my 1991 mercedes benz 190e in grand rapids?
BLUELIGHTNIN6
  • 16,542 POSTS
i'm not located near there but any local auto part store should have a replacement battery for your vehicle
KPARKER123
how do you replace the blower motor
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1475.jpg
ALLENTAN3
hi i have bought a new blower fan and new climate control switch, but after i put everything in, the fan doesnt work, it wasnt working before, so i was thinking may be i have miss some parts that caused the problem. Could u please help me out?
DOCFIXIT
  • 18,828 POSTS
Hi
Have you checked voltage to fan motor from switch through blower resistor? What is climate control switch? you mean A/C controlunit?
Let me know
Thanks for donate
ALLENTAN3
hi i got the blower fan working now, but the fan starts as soon as i start the car, even when i turn off the blower switch at the A/C control unit. Also the fan motor has some noise when it is running.
Could u please help me, thx again.
DOCFIXIT
  • 18,828 POSTS
How did you get fan to work? Must be fault in Thermatic Air Volume Switch
ABE.GUERRERO
Heater problem
1993 Mercedes Benz 190e 6 cyl Two Wheel Drive Automatic
I removed heater blower motor and checked and is okay. Replaced the 25 amp fuse of the heater blower motor and but heater blower motor still does not work. What seems to be the problem?
Check and test theTEMPMATIC AIR VOLUME SWITCH
