1989 Mercedes Benz 190e non starter
1989 MERCEDES BENZ 190E
124,600 MILES • 6 CYL • 2WD • AUTOMATIC
HCLOSEUK
  • 13 POSTS
my car refuses to start tries to fire but just wont come to life. ive replaced rotor arm/ dizzy cap/ plug leads seems to get a spark ok at the plug. also changed fuel filter fuel pump seems to be ok any help would be gratefull
Jul 10, 2008 at 2:56 PM
DOCFIXIT
  • 18,828 POSTS
Spray some carb cleaner into the intake crank it up.
Let me know what happens
Jul 10, 2008 at 3:07 PM
HCLOSEUK
  • 13 POSTS
sprayed carb cleaner in tried to start but simillar symtoms
Jul 11, 2008 at 9:34 AM
DOCFIXIT
  • 18,828 POSTS
Did it run for a sec. or two?When you say it tries does it fire, misfire ,skip? Check fire pull wire hold 1/4 in. from block crank should be blue. If not weak coil.
Also look for Vaccum leak hose etc. Have someone crank spray carb cleaner around intake throttle if she comes to life briefly there is your vac. leak
Jul 11, 2008 at 10:04 AM
HCLOSEUK
  • 13 POSTS
didnt run just skipping as if it wants to start il try your sugestions
Jul 11, 2008 at 10:07 AM
DOCFIXIT
  • 18,828 POSTS
Maybe advanced timing. Retard distributor see if it lites
Jul 11, 2008 at 10:21 AM
HCLOSEUK
  • 13 POSTS
tried adjusting ezl to different timing settings but no difference
Jul 12, 2008 at 5:24 AM
HCLOSEUK
  • 13 POSTS
when i changed the fuel filter i noticed what looked like twin fuel pumps would this be correct and if so if 1 went faulty could this result in poor fuel delivery ie not starting
Jul 12, 2008 at 2:25 PM
HCLOSEUK
  • 13 POSTS
got car started but it idles fine when driving its missing and sluggish checked leads and connections seems ok
Jul 15, 2008 at 1:29 PM
DOCFIXIT
  • 18,828 POSTS
Great news now can you get fuel pressure at idle should 40 to 48 psi
Jul 15, 2008 at 1:49 PM
HCLOSEUK
  • 13 POSTS
could the coil cause damage to the distributor cap when i replaced it the old 1 was badly burnt the carbon brush was totally gone and scorch marks around the centre
Jul 16, 2008 at 4:07 PM
DOCFIXIT
  • 18,828 POSTS
Not like that high resistance in the plug wiring may cause but lots of miles is usually what does it.
Jul 16, 2008 at 4:16 PM
HCLOSEUK
  • 13 POSTS
getting good fuel pressure upto the fuel distributor but doesnt seem to be injecting fuel to the cylinders plugs are dry after cranking over for a few minutes.
what actually gives the pressure in the fuel distributor so as i can get a better understanding of how it works
Jul 24, 2008 at 1:42 PM
