1988 Mercedes Benz 190e
1988 MERCEDES BENZ 190E
163,000 MILES • 6 CYL • 2WD • AUTOMATIC
MOORECAT2009
I started having problems a few months back with Transmission slipping or not engaging into 2nd gear, I changed tranny fluid and filter yesterday and read wheer the transmission and converter hold somewhere between 6-7 quarts of tranny fluid, my question is i changed fluid and filter out about yr ago and had some occuring problems with shifting or slipping and my question is how many of the 7 quarts does the converter hold since both times i removed tranny pan and changed fluid and filter i only added 3 quartsand keep getting inaccurate readings on the dipstick.. some people are telling me i am way low of fluid since it will not shoft after 1st gr.. now ehen i leave it shifts and nerve shifts into 2nd bu RPM's climb till i remove foot from accelerator??
Jun 7, 2009 at 2:01 PM
ZACKMAN
  • 4,202 POSTS
Between the torque converter, radiator and transmission line, they hold about 2 - 2.5 quarts. I can almost promise you that you were low to begin with when you replace the fluid the first time.
I just serviced an 89 260E a few weeks ago, I had to add 4.5 quarts before it shifted smoothly. Can't really use the dipstick level. It is not accurate until the fluid is at running temp.
Jun 8, 2009 at 12:38 AM
