1987 Mercedes Benz 190e Fuel issues
1987 MERCEDES BENZ 190E
REELDEEL
Engine Mechanical problem
1987 Mercedes Benz 190e 6 cyl Two Wheel Drive 150000 miles
Fuel issues!! 1987 190 E. If I pour gas into the carb it will start and run for about 10 seconds and then shut off. I am wondering if it could be the fuel pump or the relay and I do not know where either on of them are. is there a tell tale sign for either one malfuntioning. Thank you for your response in advance.
Feb 14, 2009 at 3:12 PM
When you turn the key do you hear the fuel pump?
Try direct battery voltage to the fuel pump connector if it comes on-check the fuel pump relay and the fuse
The fuel pump relay is located in the engine compartment on right rear firewall-sorry no picture
Feb 14, 2009 at 3:31 PM
