1986 Mercedes Benz 190e
1986 MERCEDES BENZ 190E
HUBBELLV
Engine Cooling problem
1986 Mercedes Benz 190e 4 cyl Two Wheel Drive Automatic
Hello, my boyfriend and i took my water pump out and put a new one in and there is a senser that appears to have gone missing in the day that the vehicle was sitting there. I was just wondering if you could possibly tell me what the sensor is and where it does to........
the location on the water pump where it was located is where the arrow is pointing too[img:5d65beaee9]http://www.2carpros.com/forum/automotive_pictures/522433_water_pump_1.gif[/img:5d65beaee9]
also if my battery is completely hooked up (negative and possitive) my battery will drain within a matter of hours..... where would i begin to fix that
Apr 29, 2010 at 6:24 PM
Hi hubbellv, Welcome to 2carpros and TY for the donation Verify the pic if its the same location with your pic on the water pump its called a solenoid 68a
https://www.2carpros.com/forum/automotive_pictures/12900_solenoid_1.gif
May 1, 2010 at 4:50 PM
HUBBELLV
thank you for your help but that actually did not answer my question at all that part is actually there... what i am talking about screws right into the water pump.... there is the piece that has a hose attached and then there is an electrical piece that is right below it that is what i am looking for.
May 1, 2010 at 6:54 PM
I'm using alldata reference I came up with this pic and unable to to find the part you want this is as close for a switch/sensor on the water pump I could get-sorry
May 1, 2010 at 8:09 PM
