Hi, I just rebuilt the fuel distributor and it starts up now, which is great. However, when the engine is running and I press the gas pedal, there is a significant hesitation and the car almost stalls. A few things to note:
There is about 1" gap in the air flow plate when the engine is off or idling. Every picture I've seen shows the air plate with little or no gap, so I'm not sure if this is the cause. I suspect the previous owner messed around with the plate. What is the optimal gap?
Would this be a result of the air/fuel mixture? I've tried to adjust this but the allen wrench seems to turn too easily in the fuel mixture chamber, so I'm not sure I'm actually adjusting anything.
Anything else I should consider checking?
Thanks in advance.
Thanks in advance.
Aug 24, 2020 at 10:22 AM
