brake lights not working?
2008 CHRYSLER PT CRUISER
56,000 MILES
MELINDAO777
no brake lights...Anyway, thank you for your help!!!
May 25, 2013 at 1:10 PM
More than likely this is a brake light switch issue if the third brake light is out as well.
However, if not then the TIPM is the issue. I attached the wiring diagram below that we need to use to test the voltage to determine if the TIPM is the issue.
I also attached the process for the TIPM as I suspect this is the issue.
Please let us know if you have other questions. Thanks
Jun 10, 2021 at 6:22 PM
