Welcome to 2CarPros.
I have to be honest, if it won't start with starting fluid, I need you to recheck for spark. If you have spark, starting fluid should start the engine if only for a couple seconds.
Next, what you described sounds like an issue with the crankshaft position sensor. When they start going bad, they will internally short when they get hot. The result is no spark, so please check that again.
Here are a few links that should help:
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
If you find the sensor is bad, here are the directions for replacement specific to your vehicle including adjustment. The attached pics correlate with the directions.
CRANKSHAFT POSITION (CKP) SENSOR REMOVAL/INSTALLATION
CAUTION: When foreign material such as an iron chip is on the CKP sensor, it can cause abnormal output from the sensor because of flux turbulence and adversely affect the engine control. Be sure there is no foreign material on the CKP sensor when replacing.
1. Disconnect the CKP sensor connector.
2. Remove the undercover.
3. Remove the CKP sensor installation bolt.
See Pic 1
4. Install in the reverse order of removal.
Tightening torque
7.9 - 10.7 Nm (80 - 110 kg.cm, 69.5 - 95.4 in.lb)
5. Reconnect the CKP sensor connector.
CAUTION: Do not forcefully pull the wiring harness of the CKP sensor. Doing so will break the harness.
6. Adjust the air gap. (Refer to CRANKSHAFT POSITION (CKP) SENSOR ADJUSTMENT.)
See: Crankshaft Position Sensor > Adjustments
Adjustment.
See Pic 2
1. Loosen the CKP sensor installation bolt.
2. While moving the CKP sensor, adjust the air gap between the CKP sensor and the plate teeth on the plate using a feeler gauge.
- If not adjusted within specification, replace the plate behind the crankshaft pulley or CKP sensor.
Specification: 0.5 - 1.5 mm (0.020 - 0.059 in)
3. Tighten the CKP sensor installation bolt.
Tightening torque
_______________________________________________________
Let me know if this helps. Also, if you noticed anything different as far as the engine's sound when cranking, let me know that too.
I will watch for your reply.
Jun 19, 2019 at 8:50 PM
