I just brought at 87 B2200 w/ 169000 miles. In the morning i get alot white smoke when it first starts running . I let it run and warm up the smoke stops. Problem #2.
I just gave it a tune-up and I noticed oil dripping on the lower arm of the Ex-manifold. Could this be the cause of the white smoke? Could some oil be dripping into the Ex-manifold housing through this leak? Do i need to change the Ex-manifold gasket or worst the head gasket. there also signs of previous oil leaks from somewhere esle because some areas on the engine are cover w/ dirt and oil (lower eng. block,trans,oil pan, a/c compressor). what did I get myself into? :? [b:380e00b9e7][/b:380e00b9e7]
Jul 8, 2006 at 8:41 PM
