mazda truck no spark
MAZDA TRUCK
PHIL NYLIN
i have a 1987 mazda b2000 truck with 115,000 miles, was driving along and it just died i checked for spark and nothing , changed out the coil and still nothing.engine turns over just fine .
Apr 30, 2007 at 10:24 AM
SPIKE'S AUTOMOTIVE
  • 5 POSTS
CRANKSHAFT POSITION SENSOR (SOMETIMES CALLED CRANK ANGLE SENSOR -OR- HALL-EFFECT PICKUP TRIGGER).
ON THE TIMING COVER , NEXT TO THE HARMONIC BALANCER THE SENSOR IS ATTACHED WITH 2 7MM BOLTS , & HAS A 2 CONDUCTOR LOCKING CONNECTOR.
DEPENDING ON WHICH MOTOR YOU HAVE & WHAT YEAR IT IS TOO , YOU MAY ALSO HAVE A CAM ANGLE SENSOR .
BOTH OF THESE ITEMS NEED TO BE CHECKED , AS WELL AS ALL OF THE NORMAL TROUBLESHOOTING GUIDE OF A NO-START CONDITION ON A NEWER COMPUTERIZED MODEL.
YOU SHOULD ALSO SCAN THE COMPUTER TO SEE IF IT'S FAULTY IN THE NO-START CONDITION.
SINCERELY ,
SPIKE'S AUTOMOTIVE
[email protected]
Apr 30, 2007 at 5:16 PM
