brake replacement
MAZDA TRUCK
TNALARTRAV
  • 4 POSTS
I have a 1993 Mazda B2600i with 180000 miles. I'm starting to replace the front and rear brakes. I am trying to find out if I should replace the wheel cylinder on the rear and/or the calipers on the front even if there is no sign of leakage. Also should the return springs be replaced.
I read on one repair site where the person advised replacing the cylinder when changing the drums and shoes as the new parts will be thicker and drive the inner parts of the wheel cyclinder back to the middle where there is probably dust and other junk that would cause problems down the road (leaking I believe is what he said).
I have also seen where vehicles with high mileage shouldn't replace the brake fluid because of worn parts not moving correctly with all new fluid. The brake fluid should only be topped off. Is this correct?
I want to do this right the first time and not have any reason to take it to a shop (cost almost more than the vehicle is worth).
Thank you,
Jeff
Jul 28, 2007 at 11:55 PM
[quote:7d7fdf8170="TNALARTRAV"]I have a 1993 Mazda B2600i with 180000 miles. I'm starting to replace the front and rear brakes. I am trying to find out if I should replace the wheel cylinder on the rear and/or the calipers on the front even if there is no sign of leakage. Also should the return springs be replaced.
Thank you,
Jeff[/quote:7d7fdf8170]
Determination/Funding is available I'll shoot the moon to see another 180,000miles or more, Fluid, change it and do it right.
BTW you forgot the master cylinder
Jul 29, 2007 at 4:37 AM
TNALARTRAV
  • 4 POSTS
What about the springs and wheel cylinders/ calipers.
Jul 29, 2007 at 1:14 PM
[quote:eb16aa2155="TNALARTRAV"]What about the springs and wheel cylinders/ calipers.[/quote:eb16aa2155]
If you want to save benjamins you can do a rain check on the whl cyl. and cal's if its not leaking.but I'll change the springs.
Jul 29, 2007 at 5:19 PM
