90' mazda b2600i 4wd manual clutch issue?
2012 MAZDA TRUCK
BASSG26
hello, i would first like to thank the guys answering questions on here for free. you guys are doing a great thing.
i have 90' mazda b2600i 4wd manual. with 170k miles. i just put a new clutch in my truck and i am almost positive i put everything in correctly however when i went to go start my truck, i found that i cannot move throught gears. my stick just wont go into gear. but only when the truck is running. Like the clutch isnt disengaging. also the "remote free wheel lock" light is on and it wont read that i am in 2high. My 4wheeldrive light is on unless my transfer case is in Nuetral. and when my transfer case is in Nuetral i am able to move my stick through gears.
my question is... is this problem a cause of the censors being stuck in 4? is that why i cant shift through gears? like is the truck being tricked into thinking it cant shift? or is this problem have something to do with the clutch itself or my installation? Please help! thank you guys again. - aric
Sep 28, 2007 at 1:53 PM
JRSTEINMAN
  • 8 POSTS
Sounds like you instslled your clutch incorrectly. I would just double check your instaallation. Make sure the linkage is installed correctly.
Nov 23, 2007 at 1:28 PM
