2002 Mazda Truck Rotator
2002 MAZDA TRUCK
UGMB160
Brakes problem
2002 Mazda Truck 6 cyl Two Wheel Drive Automatic
How to change the front brake rotator?
Apr 29, 2008 at 5:06 PM
SERVICE WRITER
  • 9,123 POSTS
Brake rotor?, Did you first check the manual?
IF not, check there first. Yoyu can find the link just below.
Apr 29, 2008 at 5:36 PM
BLACKOP555
  • 10,386 POSTS
Jack up the vehicle securly and remove the tire, then from there remove the brake caliper and pads.
then look at the rotor, if its the kind that has the lugs made into the rotor backing you will have to remove the wheel axle hub nut and pull out the wheel bearings and rotor, if the rotor is loose and it just sits on the spindle then the rotor will pull right off.
Apr 29, 2008 at 5:38 PM
