2000 Mazda Truck Truck Stalls Unexplained
2000 MAZDA TRUCK
62,000 MILES • 4 CYL • 2WD • MANUAL
ADAMFA
  • 5 POSTS
I own a 2000 Mazda B2500 Truck. Twice in the past 3 weeks the truck has stalled. The first time I felt it stalling and was able to park it and re-start immediately. The second time it stalled it did not start. The engine and stick shift shook violently as I tried to start it. Nothing.....Then half hour later it started immediately. No problem and ran smoothly. I went to get code check and it said no codes. I did that first time too and again, no codes. After first stall I changed fuel filter. ANY ideas? This is quite dangerous and I need your help to resolve. Thank You....
Apr 3, 2010 at 8:28 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Without codes will need to eliminate to find possible cause. Next time it is stalled and won't start pull plug wire hold to block crank spark? if spark spray carb cleaner into intake crank run?
Let me know
Thnaks for donate
Apr 6, 2010 at 1:07 PM
