1999 mazda b3000
1999 MAZDA TRUCK
SCOTTP
hello I was driving yesterday the abs light came on then my truck start to drag a bit when I stopped then started off again the speedometer did not work rpms go to about 5 to 6,000 before shifting very hard any ideas it is a Mazda b300 3.0 with 100,000 miles thank you
Sep 16, 2007 at 9:07 AM
JRSTEINMAN
  • 8 POSTS
I can probably help with the ABS light, but not the speedometer. You should get the master cylinder in the drums checked. It also sounds like you need your shoes/pads replaced (that should be what is causing the grinding). I guess for the speedometer it might be the speed sensor but not sure.
Nov 23, 2007 at 1:19 PM
