When I have the right signal on and depress the brakes the signal stops. Also the right signal indicator light goes on when I use the brakes. The signal will work fine if the breaks are not depressed. is this a short? bad ground? how do I located it an fix? or could it be a relay or fuse?
Mar 8, 2009 at 10:23 AM
