1993 Mazda Truck clutch
1993 MAZDA TRUCK
88,000 MILES • 4 CYL • 4WD • MANUAL
DENNIS MARSOLAIS
All of a sudden it became hard to get into gear. Now when the clutch is depressed it doesnt come back up. I'd like to know what you think the problem is ?
Mar 4, 2008 at 11:53 PM
MHPAUTOS
  • 31,937 POSTS
Hi there ,
It sounds like a hydraulic failure . Check the clutch fluid and if low inspect the master cylinder for leaks at the rear seal, (if leaking you will see brake fluid on the fire wall near pedal) or the slave cylinder peel back the rubber boot and if there is fluid it is no good, replace failed components and re bleed system of air.
Mark (mhpautos)
Mar 5, 2008 at 2:08 AM
