I washed my engine awhile ago, it ran rough on the drive home then it ran smooth just as I was pulling into my neighborhood. The next morning I went to start the truck and it would only crank, I've checked for spark and found I had no spark. I have a B2200 and most ignition parts are interchangeable, so I've checked my coil, distributor, I have also tried to pull my MIL codes with no success, the check engine light is on but I can't get the codes to flash. I'm wondering if it could possibly be the distributor, and if so how could I get it tested? Is there any sensors that would send the ECM a signal to not send a signal to the distributor? could it be an ECM problem?? If you have any ideas where to go with this it would be VERY appreciated.
Jan 19, 2008 at 4:56 PM
