1991 Mazda Truck need a repair manual
1991 MAZDA TRUCK
JOHNYCHAN
1991 Mazda Truck 4 cyl Four Wheel Drive Manual
is anyone who know where to find it or has one in pdf fileformat of this truck model repair manual. please could you share it with me. i really need it to fix my truck.
think you so much for sharing..
Apr 23, 2009 at 4:24 AM
What are you trying to repair?
Apr 25, 2009 at 8:18 PM
JOHNYCHAN
i keep trying and trying to start my truck but no luck. it cranks but won't start. what happen or what wrong with it?
think you for answered my question and think you for your time.
think you so much!!!!!!!
Apr 30, 2009 at 3:17 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Apr 30, 2009 at 3:50 AM
