Brake pedal suddenly went to the floorboard
1987 MAZDA TRUCK
70,000 MILES • 4 CYL • 2WD • MANUAL
SG1952
My son was driving my B2000 truck yesterday, when he said the brake pedal suddenly went to the floorboard and the brakes would not work. He pumped the pedal a number of times and they finally engaged. I first thought we had blown a wheel cylinder, but when I checked today, there did not appear to be any leaks and the master cylinder was full. I test drove the vehicle and the brakes seemed to work fine. However, I can't trust it right now. Could it be the power assist mechanism? Thanks.
Jul 20, 2008 at 7:53 PM
SQM
  • 6,383 POSTS
This could be due to a malfunctioning master cylinder.
Bad seals inside the master cylinder will not allow the brake system to build pressure when it gets applied.
Which will cause the pedal to go to the floor and it will have little to no pressure.
That will lead to very weak braking performance.
Take a look at this helpful guide:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Thank you.
Jan 29, 2022 at 10:42 PM
