1987 Mazda B2600 problems running
1987 MAZDA TRUCK
FIREFIGHTER3224
I have a 1987 Mazda B2600 4wd manual everything works great some smoking when it first starts but the big problem is that I can drive it for almost a mile until it gets to normal running temp and then it starts acting like it is stalling out then it cuts off, if i try to give it more gas it cuts off even faster,but if i restart it i can drive it for about the same amount of time maybe a little less than the first time and it does the same thing again. I changed the plugs plug wires pcv valve and I changed the oil and oil filter and the fuel filter what could be causing this anyone who can help will be greatly appreciated Thanks!!
Oct 6, 2007 at 12:46 AM
Carb or EFI system? You might want to check the EGR for carbon and then comeback.
Oct 11, 2007 at 5:54 PM
