My mechanical knowledge is limited. The clutch pedal goes all the way to the floor when depressed and does not return to the starting position. You can pull it back by hand and it will stay there until you press it again. There's very little resistance when pressed. The fluid level in the master cylinder decreases but I can't see a leak anywhere. I keep adding fluid to the cylinder but it keeps leaking out. What could be causing the pedal to stay on the floor?
Sep 9, 2010 at 11:15 AM
