1983 Mazda Truck starter clicks but engine wont crank
1983 MAZDA TRUCK
GATOJUEZ
Engine Mechanical problem
1983 Mazda Truck 4 cyl Two Wheel Drive Manual
how would i go about turning an engine that is seized or hard to start..what would be the best way to turn it over without too much difficulty..
May 6, 2008 at 11:35 PM
Put half a can of coke in each cylinder give it a few hours to work in-then manually turn the crankshaft with everything you got-if it turns 720degs change the oil and filter-
May 6, 2008 at 11:58 PM
