Engine burning smell?
2004 MAZDA RX8
KDAYO07
  • 5 POSTS
I have a problem with my rx8. I had my clutch and flywheel replace by the dealer but after that i have been getting a burning smell coming from the vent when I drive fast. even for a little bit. the engine light will start flashing and i have gotten the top of the line ignition coils but nothing. if I'm driving slow it doesn't smell but as soon as i accelerate, and have the widows down, you can smell it . you can't smell it when the AC is on or the windows are closed.. I don't want to go to the dealer and have them mess with it and mess it up even more without knowing where to look. I had the engine replace at 70,000 miles and all maintenance have been done by the dealer. i should have just bought the Z
Sep 29, 2010 at 4:07 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
The first thing you need to do is get a scan done to see why the check light is activated, do this and let me know what code is set.
mark (mhpautos)
Sep 30, 2010 at 3:05 AM
KDAYO07
  • 5 POSTS
the code is P0300. multiple misfiring which could mean anything . but the engine light only start blinking when I drive down heel, never uphill or straight. the burning smell steal there. i'm thinking that the smell is the clutch or something. any ideas
Sep 30, 2010 at 10:10 PM
MHPAUTOS
  • 31,937 POSTS
Do a clutch stall test,
With the engine running handbrake on hard select 1st and try and drive off the engine should stall as the clutch bights in, if it slips and smells, yes the clutch is faulty.
Mark (mhpautos)
Oct 1, 2010 at 3:38 AM
KDAYO07
  • 5 POSTS
I try what you told me and the engine didn't stall or no burning smell , so slipping so the clutch is fine.
I thinking about changing the spark plug and cables first. I have OKADA ignition coil that are about a year old so I don't think that is it.
Oct 1, 2010 at 9:50 AM
MHPAUTOS
  • 31,937 POSTS
OK,
do the full tune up and check for any vacuum leaks as well,
mark (mhpautos)
Oct 1, 2010 at 10:24 AM
KDAYO07
  • 5 POSTS
got it. will keep you posted
Oct 1, 2010 at 10:25 AM
MHPAUTOS
  • 31,937 POSTS
Just to let you know that i am not always on at this time of night (my time) i am in Aust and it is 1-30AM here, but i will see your posts so do not think that i have forgotten to reply if i do no come on for a while.
mark (mhpautos)
Oct 1, 2010 at 10:31 AM
KDAYO07
  • 5 POSTS
got it
Oct 1, 2010 at 10:33 AM
ITBROKE
  • 64 POSTS
My son's 2004 RX8 had a recent engine rebuild. A burning rubber smell around the rear wheel well had us concerned about a tire rubbing on something and heating up after a drive. It turned out to be the catalytic converter was getting red hot.
Oct 22, 2019 at 8:20 PM
Excellent addition to this thread!
Oct 26, 2019 at 12:24 PM
