Heater is not throwing out hot air I have it set for heat but it is only throwing out cold air
Oct 22, 2008 at 7:53 AM
2CARPRO JACK
CERTIFIED EXPERT
Check coolant level first. Then see if the heater hoses are getting hot when the car is warmed up.If it has a heater control valve inline on the heater hoses, see if iti s letting hot water into the heater core. If all that is good, you may have a problem under the dash or with the controller
