1988 Mazda RX7
1988 MAZDA RX7
200,000 MILES • 4 CYL • 2WD • MANUAL
UNSOUND
i took the alternator off to get polished , put it back on. when i did this nothing turns on , stereo, fuel pump, gauge cluster etc. what could be wrong?
Mar 8, 2010 at 1:04 PM
CARADIODOC
  • 34,306 POSTS
Look for a wire that got left off the large bolt-on terminal. Often that terminal is used as a convenient tie point.
If you didn't disconnect the battery first, suspect a blown fuse. Use a test light or voltmeter to measure the voltage on that large terminal on the alternator. If you find 0 volts, there is a blown fuse or fuse link wire. In that case, the radio and other accessory circuits will run off the alternator when the engine is running.
caradiodoc
Mar 8, 2010 at 1:28 PM
