1987 Mazda RX7 Car will not start
1987 MAZDA RX7
EUGENEPK
Engine Performance problem
1987 Mazda RX7 Two Wheel Drive Manual 120000 miles
Car will not start but will crank. Had car at Mazda dealer. Test showed good compression; new plugs. had thermostat & accelerator sensors replaced. worked fine for a month or 2 but now same problem
Aug 21, 2010 at 3:15 PM
Do below to determine if its a fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Aug 21, 2010 at 3:43 PM
