1982 Mazda RX7
1982 MAZDA RX7
WAYNE GREGORY
1982 Mazda RX7 4 cyl Two Wheel Drive Manual
What else could it be when you change the slave cylinder and it is still hard to change gears? Will be putting a new master cylinder on.
Mar 16, 2009 at 11:32 AM
RICH CRITES
  • 75 POSTS
Check to see when you push the clutch pedal down, have someone check the slave cylinder on the bell housing to see if it is moving the lever back and forth. It maybe time to replace the clutch disc and pressure plate and throwout bearing.
Apr 1, 2009 at 1:50 PM
